[postgis-users] Correct routing path, segmets of geometry
Emiliano Romero eromero at sitrack.com
Mon Apr 27 11:23:59 PDT 2009
Hi Paul, I'm happy you make it work.
paweluz escribió:
> Hi Emiliano !
> I did it :) Thanks a lot for your help. At first I didn't know what to do
> with these sql line you gave me, but finally I was able to what I have
> always wanted. The path is now correct :) Thanks a lot for your help
> Regards
> Paul
 This email and any attachments thereof may contain confidential, privileged, proprietary, or otherwise private information. This email is intended solely for the use of the individual to whom it is addressed. If you are not the intended recipient of the email and its attachments please inform the sender immediately and do not disclose the contents to any other person, use it for any purpose or store or copy the information in any way and delete this e-mail and its attachments from your system. Any views or opinions expressed are solely those of the author.
