[postgis-users] Test 1.3.6RC1 Please!
Kevin Neufeld kneufeld at refractions.net
Mon Apr 27 14:06:49 PDT 2009
Nothing serious, but there are ERRORS in the regression logs.
Creating spatial db postgis_reg
TMPDIR is /tmp/pgis_reg_11624
  PostgreSQL 8.4beta1 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-44), 32-bit
  Postgis 1.3.6RC1 - 2009-04-27 21:03:06
    GEOS: 3.1.0-CAPI-1.5.0
    PROJ: Rel. 4.6.1, 21 August 2008
Running tests
  loader/Point.............. ok
  loader/PointM.............. ok
  loader/PointZ.............. ok
  loader/MultiPoint.............. ok
  loader/MultiPointM.............. ok
  loader/MultiPointZ.............. ok
  loader/Arc.............. ok
  loader/ArcM.............. ok
  loader/ArcZ.......... ok
  loader/Polygon.............. ok
  loader/PolygonM.............. ok
  loader/PolygonZ.............. ok
  regress. ok
  regress_index. ok
  regress_index_nulls. ok
  lwgeom_regress. ok
  regress_lrs. ok
  removepoint. ok
  setpoint. ok
  simplify. ok
  snaptogrid. ok
  affine. ok
  wkt. ok
  measures. ok
  long_xact. ok
  ctors. ok
  sql-mm-serialize. ok
  sql-mm-circularstring. ok
  sql-mm-compoundcurve. ok
  sql-mm-curvepoly. ok
  sql-mm-general. ok
  sql-mm-multicurve. ok
  sql-mm-multisurface. ok
  geojson. ok
  regress_ogc. ok
  regress_bdpoly. ok
  regress_ogc_cover. ok
  regress_ogc_prep. ok
  regress_proj. ok
  kml. ok
Run tests: 40
Failed: 0
[buildbot at falcon regress]$ grep ERROR /tmp/pgis_reg_11624/*
/tmp/pgis_reg_11624/dumper.err:Initializing... ERROR: Cannot determine spatial reference (empty table or unknown spatial
ref).
/tmp/pgis_reg_11624/regress_log:ERROR:  table "loadedshp" does not exist
-- Kevin
Paul Ramsey wrote:
> In order to support PostgreSQL 8.4 when it is released, we need
> another point release on the 1.3.X series. There is now a release
> candidate available for your testing, please avail yourself of the
> opportunity to make sure it works for you.
> http://postgis.refractions.net/download/postgis-1.3.6rc1.tar.gz
> Thanks,
> The PostGIS Team
> postgis-users mailing list
