[postgis-users] Lambert72 to WGS84
Nicolas Ribot nicky666 at gmail.com
Tue Apr 28 06:30:48 PDT 2009
> 1. Which postGis methods do I use for converting Lambert72 coordinates to
> WGS84 coordinates and vice-versa?
> 2. Does anybody know of a Java library that implements this conversion or
> which I can use to implement it?
Hi Guy,
Yes, GeoTools will allow you to perform this conversion.
GDAL/OGR, through the Java binding, would also do the job, afaik.
Nicolas
