[postgis-users] Point on a surface doesn`t touch geometry?
Martin Davis mbdavis at refractions.net
Tue Apr 28 08:28:42 PDT 2009
Also, the point probably doesn't lie *exactly* on the geometry due to
roundoff error.
It's correct that Overlaps returns FALSE, since an interior point does
not overlap its containing geometry.  Intersects should have returned
TRUE however - IF the point was precisely on a line segment.  This is
unlikely to happen in the general case.
Nicolas Ribot wrote:
>> Dear users,
>> with "SELECT astext(pointOnSurface(the_geom)) from ways where gid=14730"
>> I get the coordinates of a point that lies on the surface of a MULTILINESTRING.
>> I get: POINT(897169.996155569 6850066.73917209)
>> Then I try
>> SELECT overlaps (the_geom,Geomfromtext('POINT(897169.996155569 6850066.73917209)',900913)) from ways where gid=14730;
>> ...and I get FALSE ???
>> (I also tried with "touches" and "intersects" --> the
>> result there also FALSE).
>> Has anybody an idea how this can be?
> Hi Kai,
> Yes, this can be because of the OGC specifications, that define very
> precisely these predicates, in terms of relationship between interior,
> boundary and exterior of each object.
> A point cannot overlap a polygon, for instance (as far as I remember)
> Looking at the predicates definitions in the specifications may help
> to understand what they mean, for each kind of objects (points, lines,
> polygons):
> http://www.opengeospatial.org/standards/sfs
> (don't trust your 'human' understanding of what 'touches' or 'overlaps' mean)
> You may also look at the Jump documentation, as it contains nice
> graphics showing some common misunderstandings with these predicates
> (http://www.vividsolutions.com/JUMP/)
> HTH
> Nicolas
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
