[postgis-users] ST_Union (8.4) and TopologyException
Robert Coup robert.coup at onetrackmind.co.nz
Tue Aug 4 18:34:36 PDT 2009
On Wed, Aug 5, 2009 at 12:17 PM, Simon Greener
<simon at spatialdbadvisor.com>wrote:
> I have had to use ST_Transform as I have found the query even more
> problematic when run against the original geodetic data.
Projections are a very likely cause of topology errors for accurate data...
how was it more problematic for geodetic data - more topology errors?
Does:
SELECT count(*) FROM mytable WHERE (geom IS NOT NULL) AND (NOT
st_isvalid(st_transform(geom,
96687)));
return anything for either of the tables?
Rob :)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090805/0d8823f5/attachment.html>
