[postgis-users] Invalid OGC WKT (does not start with P, L, M, C or G) - but just on INSERT
Paragon Corporation lr at pcorp.us
Sun Aug 9 15:21:03 PDT 2009
 Andreas,
You really should qualify the columns you are inserting into. Most likely
the is is the order of columns in your table is different from how you are
inserting.  Its quite possible you are not inserting the geometry into the
geometry column.  Do something like this instead then you don't have to
worry about the physical order of your columns
insert into feature_geom(some_field, gid, the_geom)
 values('Relation', 1,
ST_GeomFromText('MULTIPOLYGON(((0 0,1 1,2 2,0 0)))', 4326));
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas
Kalsch
Sent: Sunday, August 09, 2009 6:13 AM
To: PostGIS Users Discussion
Subject: [postgis-users] Invalid OGC WKT (does not start with P, L, M, C or
Why is this error thrown although the text is valid? When I select, it will
not be thrown.
b=# insert into feature_geom values('Relation', 1,
ERROR:  Invalid OGC WKT (does not start with P,L,M,C or G)
CONTEXT:  SQL function "st_geomfromtext" statement 1
PL/pgSQL function "feature_geom_insert" line 6 at assignment
b=# select st_geomfromtext('POINT(0 0)', 4326);
                  st_geomfromtext
 0101000020E610000000000000000000000000000000000000
(1 row)
b=# select st_geomfromtext('MULTIPOLYGON(((0 0)))', 4326);
ERROR:  geometry requires more points
b=# select st_geomfromtext('MULTIPOLYGON(((0 0,1 1,2 2,0 0)))', 4326);
st_geomfromtext
0106000020E61000000100000001030000000100000004000000000000000000000000000000
00000000000000000000F03F000000000000F03F000000000000004000000000000000400000
b=# SELECT postgis_full_version() ;
 POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.1, 21 August
2008" USE_STATS
(1 row)
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
