[postgis-users] Finding the buffer of two points
Fred Lehodey lehodey at gmail.com
Tue Aug 11 04:00:25 PDT 2009
pgRouting:
http://pgrouting.postlbs.org
Fred
On Tue, Aug 11, 2009 at 11:48 AM, Supunmali Ahangama
<supunmali7 at gmail.com>wrote:
> Hi,
> I have two points A and B located in a large region. I need to find the
> optimal path between those 2 points. Without considering the whole area
> (all
> the edges), can I consider only a segment that will be required to find the
> optimal path. As all the edges (far away roads in other cities) will not be
> required to find the optimal path between two points in a city. If all are
> considered it will be a waste.
> What is the possible function to use and how to solve my issue?
> Hope to hear a reply soon. Thanks
> http://www.nabble.com/Finding-the-buffer-of-two-points-tp24915312p24915312.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090811/3843a49e/attachment.html>
