[postgis-users] Acces to grid creation functions ?
Maxime van Noppen maxime at altribe.org
Fri Aug 14 02:46:52 PDT 2009
On 08/14/09 11:42, Mark Cave-Ayland wrote:
> Ah okay. Those functions actually snap to grid rather than just generate
> it, so it's not quite as simple as that.
Ok.
> I think there are some grid examples on the wiki which may help you:
> http://trac.osgeo.org/postgis/wiki/UsersWikiMain. Alternatively, it
> should be fairly easy to knock up something using the in-built
> PostgreSQL generate_series() function.
It's indeed fairly easy to do. It was just to avoid reinventing the
wheel if it was already implemented somewhere.
Maxime
