[postgis-users] functions st_covers, st_coveredby, st_simplifypreservetopology does not exist
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Aug 14 05:02:15 PDT 2009
Pena Kupen wrote:
> Hi,
> I install geos 3.1.1 from source and try the same.
> There where no difference - same errors occurred again.
> How to find out, which version of geos my scripts are using?
> ideas?
> pk
In the 1.3 branch, PostGIS simply picks up the version of GEOS as
indicated by the geos-config executable in the current path. So the
quick check would be:
geos-config --version
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
