[postgis-users] getting a square/rectangle arround a point
Pavel Iacovlev iacovlev.pavel at gmail.com
Tue Aug 18 09:43:08 PDT 2009
st_intersection(st_envelope(st_buffer(t1.the_geom, $radius)), t2. the_geom)
2009/8/18 Daniel Grum <daniel.grum at unibw.de>:
> Dear Mailing-List,
> I want to create a square/rectangle around a point-->via box2d(geometry) or
> buffer(geometry, double precision) for example.
> If I have this rectangle I want to intersect this with another polygon-->
> saved in the (geodata) table: wald_by column: the_geom, to get information
> about the area the the "lumberjack" can dig.
> The point in the middle of the rectangle = the point that is saved in a
> table in my database in the table: holzfaeller in the column the_geom!
> Is this possible to solve?
> Do I have to save this calculated square/rectangle in an extra/own table?
> Thanks for every help.
> Daniel
> postgis-users mailing list
http://iap.md, The future is open
