[postgis-users] Split multi-linestrings
Ben Madin ben at remoteinformation.com.au
Wed Aug 19 06:11:10 PDT 2009
Thanks Fred,
I have also had this problem, but I don't understand how to handle the
'set' that is returned.
I don't seem to be able to split out each LINESTRING into its own row.
Is there a way to do this or handle the 'set' output?
(It may just be incorrect programming on my part, but I have tried all
the examples from the documents, and get a geometry 'set' - I just
can't do anything with it!)
cheers
Ben
On 19/08/2009, at 6:54 PM, Fred Lehodey wrote:
> Hi Andrea,
> Have a look to ST_Dump
> http://postgis.refractions.net/docs/ST_Dump.html
> Fred
> On Wed, Aug 19, 2009 at 11:50 AM, Andrea Peri <aperi2007 at gmail.com>
> wrote:
> Hi,
> I have some troubles try-ing to split from a MultiLineString to
> LineStrings.
> I try this code with postgis 1.4.0:
> ST_GeometryN(geom,generate_series(1,ST_NumGeometries(geom)))
> But it return all LineStrings as simple segments with 2 only vertexs.
> It seem the ST_NumGeometries(geom) return the count of all
> segments , not the parts.
> There a function that count the num of parts ?
> Many thx,
> Andrea Peri
> postgis-users mailing list
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090819/db3f1fda/attachment.html>
