[postgis-users] install problems Postgis 1.4.0 with Postgres 8.4.0 on Mac OS X 10.5
P Kishor punk.kish at gmail.com
Thu Aug 20 17:24:55 PDT 2009
I should have mentioned, I installed 8.4.0/1.4.0 on an existing
install of 8.3.7/1.3.x. Seems like the old liblwgeom.so not get
replaced by a new one. Why not?
On Thu, Aug 20, 2009 at 6:25 PM, P Kishor<punk.kish at gmail.com> wrote:
> I did a pretty plain vanilla Postgres 8.4.0 and Postgis 1.4.0
> installation on my Macbook, but am getting the following error when
> trying to build my first db
> Lucknow:~ postgres$ /usr/local/pgsql/bin/psql -d punkish -f
> /usr/local/pgsql/share/lwpostgis.sql
> BEGIN
> psql:/usr/local/pgsql/share/lwpostgis.sql:44: NOTICE:  type
> "histogram2d" is not yet defined
> DETAIL:  Creating a shell type definition.
> psql:/usr/local/pgsql/share/lwpostgis.sql:44: ERROR:  incompatible
> library "/usr/local/pgsql/lib/liblwgeom.so": version mismatch
> DETAIL:  Server is version 8.4, library is version 8.3.
> psql:/usr/local/pgsql/share/lwpostgis.sql:50: ERROR:  current
> transaction is aborted, commands ignored until end of transaction
> block
> How did I end up with a mismatch between the server and the
> liblwgeom.so lib? And, most importantly, what do I do to correct this?
> Many thanks in advance,
> Puneet Kishor http://www.punkish.org
> Carbon Model http://carbonmodel.org
> Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
> Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
> Nelson Institute, UW-Madison http://www.nelson.wisc.edu
> Assertions are politics; backing up assertions with evidence is science
