[postgis-users] install problems Postgis 1.4.0 with Postgres 8.4.0on Mac OS X 10.5
Paragon Corporation lr at pcorp.us
Thu Aug 20 17:40:20 PDT 2009
Punish,
It sounds like you are using the wrong script and some how you also managed
to load a 1.3 liblwgeom for 8.3 on an 8.4 install.  If you are using PostGIS
1.4.0 then you should be using a script called postgis.sql
As of PostGIS 1.4.0 the postgis lib is also versioned.
So while the old ones were always called liblwgeom
the new ones will be called
postgis-1.4
postgis-1.5
and so on.
and of course it appears your liblwgeom while being for PostGIS 1.3 probably
is not even for 8.4 but is for 8.3
Did you compile your own install or did you get from somewhere?
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of P Kishor
Sent: Thursday, August 20, 2009 7:26 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] install problems Postgis 1.4.0 with Postgres
I did a pretty plain vanilla Postgres 8.4.0 and Postgis 1.4.0 installation
on my Macbook, but am getting the following error when trying to build my
first db
Lucknow:~ postgres$ /usr/local/pgsql/bin/psql -d punkish -f
/usr/local/pgsql/share/lwpostgis.sql
BEGIN
psql:/usr/local/pgsql/share/lwpostgis.sql:44: NOTICE:  type "histogram2d" is
not yet defined
DETAIL:  Creating a shell type definition.
psql:/usr/local/pgsql/share/lwpostgis.sql:44: ERROR:  incompatible library
"/usr/local/pgsql/lib/liblwgeom.so": version mismatch
DETAIL:  Server is version 8.4, library is version 8.3.
psql:/usr/local/pgsql/share/lwpostgis.sql:50: ERROR:  current transaction is
aborted, commands ignored until end of transaction block
How did I end up with a mismatch between the server and the liblwgeom.so
lib? And, most importantly, what do I do to correct this?
Many thanks in advance,
Puneet Kishor http://www.punkish.org
Carbon Model http://carbonmodel.org
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
Nelson Institute, UW-Madison http://www.nelson.wisc.edu
Assertions are politics; backing up assertions with evidence is science
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
