[postgis-users] 1.3 to 1.4 upgrade
Paragon Corporation lr at pcorp.us
Fri Aug 21 11:27:43 PDT 2009
Mark,
As long as you don't backup with clean drop it should work fine.  The
restore will fail  when it trys to restore something already in the db and
just skip over that object.  So in the end you get all the new stuff + newer
versions and all the old stuff thats not in the new stuff.
The only caution I can think of is with the spatial ref sys if you have
custom entries.  You may want to restore that first and delete the one that
comes packaged with new install or just add in your custom entries.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Matt
Foster
Sent: Friday, August 21, 2009 8:51 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] 1.3 to 1.4 upgrade
When you say you restore your 1.3 on top of a new 1.4 install, do you mean
that you dump your data only from the 1.3, and insert that into the new 1.4?
I didn't know that would work.
I did use the Perl script.
This on on RHEL 5 x86_64.
Matt
Paragon Corporation wrote:
> Those errors look fine to me.  Those things don't exist in PostGIS 1.4
> so they simply won't be loaded.
> Are you using the perl upgrade script.  Haven't tried that so not
> absolutely sure.  We usually just restore our old 1.3 ontop of a new
> mint PostGIS 1.4 and that works pretty well for us, but then again we
> were doing both migrations at the same time.
> Which platform are you on by the way?
> Leo
> Matt Foster
> Sent: Thursday, August 20, 2009 12:06 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] 1.3 to 1.4 upgrade
> Hello,
> I'm moving some Postgis databases to a new physical server.  I decided
> to use this opportunity to move from Postgis 1.3 to 1.4.  I'm also
> going from Postgres 8.2 to 8.3 (I'm not brave enough to go to the brand
new PG 8.4!).
> I concluded that the right thing to do was to use the "Hard Upgrade"
> method to make this move.  When I ran the upgrade Perl script to
> restore the dump on to the new server, I got the following error
messages...
> ERROR:  language "plpgsql" already exists
> ERROR:  function st_histogram2d_in(cstring) does not exist
> ERROR:  could not access file "$libdir/liblwgeom": No such file or
> directory
> ERROR:  function public.asukml(geometry, integer, integer) does not
> exist
> directory
> ERROR:  function public.asukml(geometry, integer) does not exist
> directory
> ERROR:  function public.asukml(geometry) does not exist
> directory
> ERROR:  function public.st_asukml(geometry, integer, integer) does not
> exist
> directory
> ERROR:  function public.st_asukml(geometry, integer) does not exist
> directory
> ERROR:  function public.st_asukml(geometry) does not exist
> directory
> ERROR:  function public.st_text(boolean) does not exist
> directory
> ERROR:  function public.text(boolean) does not exist
> Following the documentation, I grep'd for ^KEEPING in the log file I
> created, and found these entries...
> KEEPING TYPE [histogram2d]
> KEEPING FUNCTION: [askml(geometry, integer, integer)] KEEPING FUNCTION:
> [asukml(geometry, integer, integer)] KEEPING FUNCTION:
> [asukml(geometry, integer)] KEEPING FUNCTION: [asukml(geometry)] KEEPING
FUNCTION:
> [st_askml(geometry, integer, integer)] KEEPING FUNCTION:
> [st_asukml(geometry, integer, integer)] KEEPING FUNCTION:
> [st_asukml(geometry, integer)] KEEPING FUNCTION: [st_asukml(geometry)]
> KEEPING FUNCTION: [st_text(bool)] KEEPING FUNCTION: [text(bool)]
> KEEPING
> FUNCTION: [update_geometry_stats()] KEEPING FUNCTION:
> [update_geometry_stats(character varying, character varying)] KEEPING
> AGGREGATE [geomunion(geometry)]
> Are these messages normal or are they indicating a problem?  Some
> searching of the mailing list archive led me to believe that they are
> normal, but I would like to be sure before I proceed with the other
databases.
> Matt
> Do not go where the path may lead; go instead where there is no path
> and leave a trail.
> -- Ralph Waldo Emerson
> postgis-users mailing list
Do not go where the path may lead; go instead where there is no path and
leave a trail.
