[postgis-users] DELETE old lines in a table
Daniel Grum daniel.grum at unibw.de
Wed Aug 26 07:43:44 PDT 2009
Hi all,
I've a problem with deleting old infos in a table.
I want put information into a table via "insert into" and delte the old
information that was saved in the tabele befor.
In adition to the "gid" column I have a column, called
"zeitstempel"(timestamp), that shows me what info is old and what is the
latest infos.
Here is the sql:
INSERT INTO abbauholz
SELECT nextval('serial') AS GID,
       pt.name AS name,
       ST_Intersection(poly.the_geom,ST_Expand(pt.the_geom, 2000)) AS
the_geom,
       Area(ST_Intersection(poly.the_geom,ST_Expand(pt.the_geom, 2000)))
AS flaeche,
       Sum(Area(ST_Intersection(poly.the_geom,ST_Expand(pt.the_geom,
2000)))) AS sum_flaeche,
       CURRENT_TIMESTAMP AS zeitstempel
FROM public.wald_by poly, public.holzfaeller pt
WHERE poly.the_geom && ST_Expand(pt.the_geom, 2000)
GROUP BY pt.name, poly.the_geom, pt.the_geom;
DELETE FROM abbauholz WHERE date_part('second',zeitstempel) <
date_part('second', CURRENT_TIMESTAMP);
the last line is the most important, because here came DELETE order.
But it doesn't work, the old info(old lines) stay in the table after the
sql order.
Can someone help me?
--daniel
