[postgis-users] PostGIS memory leak bug
Paragon Corporation lr at pcorp.us
Wed Aug 26 20:50:18 PDT 2009
Which version of GEOS are you running
run a
SELECT postgis_full_version();
Most of issues with memory leaks in the past have happened in the GEOS layer
as I recall.
Hope that helps,
Regina
  _____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
WANGRUNGVICHAISRI, SHIVESH
Sent: Wednesday, August 26, 2009 7:30 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] PostGIS memory leak bug
We have an example program that should demonstrate a memory leak in
postgres.exe caused by PostGIS when used in a multi-threaded situation.
The link to the entire zip file is here:
http://www.2shared.com/file/7399978/56887b86/Postgis_Leak.html
OS: Windows XP 32-bit
PostgreSQL: 8.3.7
PostGIS: 1.3.6
Thanks,
S.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090826/a3b2e6bb/attachment.html>
