[postgis-users] PostGIS memory leak bug
Kevin Neufeld kneufeld at refractions.net
Thu Aug 27 00:00:40 PDT 2009
Just thinking this through out loud here ... as I understand it, your
test program runs two threads at the same time.
Thread 1 inserts into a table with a simple geometry object.
Thread 2 selects from the same table at the same time the inserts are
happening.
I'm not sure, but I think PGConn from libpq defaults to having
autocommit set to true.  Nevertheless, you might not be experiencing a
memory leak at all, but rather growing transaction blocks within postgresql.
Since you don't add a spatial index to your test table, it naturally
takes longer and longer to query the table using ST_Contains in your
select thread since the query would be performing sequential scans
through the entire table every time.  So, as you perform a long running
query against a table in one transaction block, you are inserting into
the same table as fast as you can in a different transaction block ...
and at the same time autovacuum kicks in trying to ANALYZE your growing
table in a futile attempt to kept the stats up to date.
You probably see the memory allocations grow faster than normal due to
the larger footprint of a geometry object.  I'm curious, do you see the
memory climb using other data types?
Having said that, Regina is right that there were a few nasty leaks in
GEOS a while back.  Make sure you are using the latest stable build.
-- Kevin
WANGRUNGVICHAISRI, SHIVESH wrote:
> We have an example program that should demonstrate a memory leak in
> postgres.exe caused by PostGIS when used in a multi-threaded situation.
> The link to the entire zip file is here:
> http://www.2shared.com/file/7399978/56887b86/Postgis_Leak.html
> OS: Windows XP 32-bit
> PostgreSQL: 8.3.7
> PostGIS: 1.3.6
> Thanks,
> S.
> postgis-users mailing list
