[postgis-users] postgis slow performance
Ben Madin ben at remoteinformation.com.au
Thu Aug 27 18:48:55 PDT 2009
I probably can't help, but am interested in the optimisation of my own
tables.
However, without knowing a bit more about your setup I doubt anyone
else can either.
The output of
	select postgis_full_version();
is a good starting point.
Other details like EXPLAIN output, how big is the table, what other
columns are there, is it in a separate tablespace, etc. are often
useful.
Maybe submit that now so when other's look at it they have a bit more
to work on.
cheers
Ben
On 28/08/2009, at 1:35 AM, Narayanan, Divya wrote:
> We were testing some queries to improve performance and found that
> the queries using PostGIS were slower than those that did not.
> I’ve included one of the queries tested
> Query with PostGIS
> SELECT ntb.id
> FROM navteq as ntb
> WHERE ( ntb.positioned_tsv @@ '(hotel|hodels|hoteles)'::tsquery)
> AND (latitude>34.00846 AND latitude<34.09855 AND
> longitude>-118.29926 AND longitude<-118.1907)
> LIMIT 250
> Query time: 1 second
> Query using postgis:
> SELECT ntb.id
> FROM navteq_xtd_noothers as ntb
> AND geom && ST_SetSRID(ST_MakeBox2D(ST_Point(-118.29926,
> 34.00846),ST_Point(-118.1907, 34.09855)),4269)
> LIMIT 250
> Query time: 4 seconds
> The latitude and longitude columns are indexed. The geom column uses
> a GIST index. We’re using Postgres v 8.1. Is there something we’re
> doing wrong? Please let me know if you need more information.
> Thanks,
> Divya
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090828/710504a1/attachment.html>
