[postgis-users] count points for every polygon
Astrid Emde astrid.emde at wheregroup.com
Tue Dec 1 01:23:38 PST 2009
Hello Alexander,
have a look at
http://postgis.org/documentation/manual-1.4/ch07.html
and try
* ST_NumPoints - to get the Number of Points of a Linestring
* ST_ExteriorRing - to get a linestring from your Polygon
* if you have MULTIPOLYGONS you may need ST_NumGeometries, ST_GeometryN
Best regards
Astrid
On Tue, December 1, 2009 8:58 am, Alexander Strunck wrote:
> hello
> i am new to postgis and sql. my problem is that i want to count the
> points that are in every polygon. the polygon table contains gid, id,
> geom. the points table contains id, geom. i found in the internet this sql
>> UPDATE polygon SET number_points = foo.count
>> FROM (
>> SELECT polygon.name, count(point.gid) AS count
>> FROM point, polygon
>> WHERE ST_Contains(polygon.the_geom, point.the_geom)
>> GROUP BY polygon.name
>> ) AS foo
>> WHERE polygon.name = foo.name;
> but it don´t seem to work for me.
> Has anyone an idea how to make this work??
> thx
> alex --
> Endlich! Das Debüt-Album von Pop-Diva Sarah Kreuz ist da!
> Jetzt bei GMX Musik Downloads. http://portal.gmx.net/de/go/musik01
> postgis-users mailing list postgis-users at postgis.refractions.net
