[postgis-users] Length of Bigint, Double and Text fields
Tue Dec 1 08:11:45 PST 2009
Mark Cave-Ayland wrote:
> Hi Peter,
> You've brought up some interesting points here. Can you actually clarify
> these changes with regard to parts of the official shapefile spec, or
> have they been found purely through experimentation?
Mark,
I would note that the shapefile specification is essentially silent on
the details of the .dbf file, apparently under the assumption that this is
a well known format from other sources and does not need to be specified.
Best regards,
