[postgis-users] Length of Bigint, Double and Text fields
Gerald Creager gerry.creager at tamu.edu
Tue Dec 1 09:30:27 PST 2009
My experience in the past (including some .dbf imports by several
systems, including legaccy dBase IV, was that in fact, these are dB-IV
.dbf's.  The difference is small, as noted below, between v. III and v.
IV.
gerry
Peter Hopfgartner wrote:
> Chris Hermansen wrote:
>> Peter;
>> The canonical description of DBase files seems to be
>> http://www.clicketyclick.dk/databases/xbase/format/
> Well, first of all, I do not know which dBase version is targeted by
> ArcGIS.
> Second, I doubt the exact values in
> http://www.clicketyclick.dk/databases/xbase/format/data_types.html#DATA_TYPES.
>  From our tests, both dbase III and dBase IV can handle text fields <=
> 254 characters (and not < 254).
> Further, dBase III can handle numerics with <= 19 digits and not < 18
> digits. dBase IV limits this to <= 20 digits.
> The above mentioned tool identifies ArcGIS generated files as dBase IV,
> in clear conflict on what is said in the above mentioned Wikipedia article.
> Cheers,
> Peter
>> On Tue, 2009-12-01 at 17:28 +0100, Peter Hopfgartner wrote:
>>>>> Dear PostGIS devels,
>>>>> since we right in the middle of comparing interoperability of shape
>>>>> files between some FOSS programs and ArcGIS, we encoutered also the
>>>>> following:
>>>>> gvSIG chokes on the Bigint as produced by pgsql2shp. Looking at
>>>>> ArcGIs generated files, the max length for numbers is 19, compared
>>>>> to 20 for integers and 32 for floating points as in pgsql2shp. This
>>>>> seems to be confirmed by some Borland tools, when configured for
>>>>> dBase III+.
>>>>> Another limit seems to be that of text fields, that must be no
>>>>> longer then 254. This is the maximum as given by ArcGIS and by the
>>>>> Borland tool.
>>>>> Another point is Boolean: ArcGIS seems to not allow the creation of
>>>>> boolean fields and the Borland Tool ("Database Desktop") says that
>>>>> Booleans have a length of 1.
>>>>> Regards,
>>>>> Peter
>>>> Hi Peter,
>>>> You've brought up some interesting points here. Can you actually
>>>> clarify these changes with regard to parts of the official shapefile
>>>> spec, or have they been found purely through experimentation?
>>>> ATB,
>>>> Mark.
>>> Hi Mark,
>>> I do still have to figure out, if there are public specs for this.
>>> All I've found is, that attributes should be in data base files which
>>> are in dBase format
>>> (http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf). From
>>> the analysis of the file (and Wikipedia:
>>> http://en.wikipedia.org/wiki/Shapefile), it seems that this should be
>>> dBase III. I do not have any evidence that there is a public spec for
>>> dBase III.
>>> So all we did is basically gather some experimental data, where
>>> ArcGIS and gvSIG are our references. The first, because ESRI
>>> introduced the shape file format and gvSIG, because it is the desktop
>>> environment that we encourage our customers to use. Anyway, we have
>>> an old Borland/Inprise tool ("Database Desktop") here for managing
>>> dBase files and used it for our tests.
>>> Peter
> postgis-users mailing list
