[postgis-users] Making a Polygon from Points
David Potts dave.potts at pinan.co.uk
Sun Dec 6 02:31:28 PST 2009
Hi
I trying to make a polygon or closed linestring from a list of points.
I can say something like
 insert into lines(the_geom) select ST_MakeLine(foo.the_geom) from(select
the_geom from hack where generation=1 and circle=0 ) as foo;
This results in a open line that runs through all off the points,  I am
trying to generate either a closed line or a polygon.
Using functions like  ST_Polygonize, generate an empty goetry collection.
Does anybody have any suggestions on how I generate a closed linestring or
a polygon?
regards
Dave.
Any views expressed in this message are those of the individual sender,
except where the sender specifically states them to be the views of the
Pinan Software
