[postgis-users] Suggestion Needed
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon Dec 7 12:27:02 PST 2009
Mukesh,
Sorry for the late answer. You can give a try to WKT Raster. You will have to compile it though. Loading Geotiff should then be straightforward using gdal2wktraster.py.
Pierre
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of mukesh karanwal
Sent: 25 novembre 2009 06:30
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Suggestion Needed
Hi..
thanks for the reply.
i did it but still it is showing the same error!
I actually want to store a Geotiff file in the databse, could you please tell, is there any other way to do this? or where am i doing mistake, if any?
Thanks
--- On Tue, 11/24/09, Luigi Castro Cardeles <luigi.cardeles at gmail.com> wrote:
From: Luigi Castro Cardeles <luigi.cardeles at gmail.com>
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Tuesday, November 24, 2009, 10:17 PM
to "bypass" the password, you can make the .pgpass file and fill that with your connection params (hostname:port:database_name:user:password).
If you are using windows, the path is: C:\Users\<your user name>\AppData\Roaming\postgresql\.pgpass
best regards
2009/11/24 mukesh karanwal <mukesh_karanwal at yahoo.com<http://us.mc459.mail.yahoo.com/mc/compose?to=mukesh_karanwal@yahoo.com>>
Hey Everyone,
I am trying to store raster data in Postgis/PostgrSQL using "geotiff2pgrstaer.exe". but evertime i get an error that "when making connection to PostgreSQL: fe_sendauth: no password supplied", though i am supplying all the information.
The command i am giving is like:
C:\..> geotiff2pgraster -h localhost -p 5432 -d postgis -U postgres -P <mypassword> data.tif(strored at this location only) tablename
Kindly tell the remedy for the above problem and also is there any other way out to store raster data until now?
Thanks in anticipation
With Regards,
Mukesh
postgis-users mailing list
postgis-users at postgis.refractions.net<http://us.mc459.mail.yahoo.com/mc/compose?to=postgis-users@postgis.refractions.net>
http://postgis.refractions.net/mailman/listinfo/postgis-users
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091207/d9676d4b/attachment.html>
