[postgis-users] Trouble after upgrade to 1.4.0
Peter N. Schweitzer pschweitzer at usgs.gov
Wed Dec 9 06:56:22 PST 2009
Paragon Corporation wrote:
> No,but it looks like you are just being bitten by the missing autocast in
> the upgrade script which I think we have fixed in 1.4.1
> See my comment here
> http://trac.osgeo.org/postgis/ticket/223
> So short answer -- your problems should be solved if you run the below
> CREATE CAST (box3d_extent AS box3d)
> WITH FUNCTION st_box3d_extent(box3d_extent) AS IMPLICIT;
> There is another problem I ran into I describe which hopefully I'm the only
> one in the world affected by this other change.
Regina,
Thanks for the pointer.  I could execute that create cast function
but that didn't eliminate the error.  Following a comment in the ticket,
I now write
select ST_Box2d(ST_Transform(ST_SetSRID(ST_Extent(the_geom)::box3d,4267),3395)) from
and this works without error.  Is this what you would expect?
Peter
Peter N. Schweitzer (MS 954, U.S. Geological Survey, Reston, VA 20192)
(703) 648-6533  FAX: (703) 648-6252  email: pschweitzer at usgs.gov
<http://geology.usgs.gov/peter/>
