[postgis-users] ST_INTERSECT returns false, but should return true
Satish Murthy satish_m at hotmail.com
Wed Dec 9 07:48:52 PST 2009
I can't figure out why this is happening:
This works, returning true:
SELECT Intersects(
GeomFromEWKT('MULTILINESTRING((-26.9599999999939 -29.97 1 0,-26.9399999999976 -29.99 2 0),(-25.8599999999937 -29.97 1 0,-26.9399999999976 -29.99 2 0))'),
    GeomFromEWKT('POINT(-26.9599999999939 -29.97 1 0)')) ;
If I select the same as geometries, it returns false
SELECT ST_Intersects(
(select geom1 from tab),
    (select geom2 from tab)) ;
Weird thing is,
   select ST_DISTANCE (geom1, geom2)
returns 3.51700710773038e-14
This behavior is not consistent - sometimes ST_INTERSECTS returns true correctly.
What is the problem here.
Thanks,
Satish
_________________________________________________________________
Windows 7: Simplify what you do everyday. Find the right PC for you.
http://windows.microsoft.com/shop
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091209/216d7008/attachment.html>
