[postgis-users] how obtain the interior parcels
Fred Lehodey lehodey at gmail.com
Thu Dec 10 11:48:17 PST 2009
Hi Salas,
are "interior parcels" islands ?
ST_NumInteriorRings(geometry)
Return the number of interior rings of the first polygon in the geometry.
Return NULL if there is no polygon in the geometry.
ST_NumInteriorRing(geometry)
Synonym to NumInteriorRings(geometry). The OpenGIS specs are ambiguous about
the exact function naming, so we provide both spellings.
ST_InteriorRingN(geometry,integer)
Return the N'th interior ring of the polygon geometry. Return NULL if the
geometry is not a polygon or the given N is out of range.
Fred.
On Thu, Dec 10, 2009 at 7:35 PM, Fsalas <fsalas at geocuba.cu> wrote:
>  Hi,
> I have a table parcels , and I need obtain the list of the only interior
> parcels, the parcels is not overlap.
> I test ST_Contains(), ST_Intersects() but the result is not correct.
>  Salas.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091210/506b8ab0/attachment.html>
