[postgis-users] Weird GEOS problem
Emilie Laffray emilie.laffray at gmail.com
Fri Dec 11 03:13:03 PST 2009
2009/12/11 George Vlahakis <g.vlahakis at telenavis.com>
>  Hi all,
> Probably nobody has seen this, but on a particular machine (Win XP) every
> 2-3 hours or so I am getting the following error:
> System.Data.Odbc.OdbcException: ERROR [XX000] ERROR: Error creating GEOS
> Coordinate Sequence; Error while executing the query
I might be wrong but you are using .NET?
If it is indeed the case, I would suggest dropping the use of odbc, and use
npgsql which provides a direct connection to the database. It should give
you better performance, and maybe extra stability.
Emilie Laffray
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091211/6e62de98/attachment.html>
