[postgis-users] Weird GEOS problem
George Vlahakis g.vlahakis at telenavis.com
Wed Dec 16 07:54:14 PST 2009
Hi Emilie,
Im trying to port over to npgsql but I cannot get the GeomFromWKB
function to get called correctly. No matter what I do with the wkb
parameter the query failes (error near \",\"). Any hints?
                const string sql = "INSERT INTO table ("
                                   + "client, category, description,
geom)"
                                   + " VALUES (?, ?, ?, GeomFromWKB(?,
4326)) RETURNING id";
                cmd = new NpgsqlCommand(sql, conn);
                cmd.Parameters.Add(string.Empty, request.ClientId);
                cmd.Parameters.Add(string.Empty, request.CategoryId);
                cmd.Parameters.Add(string.Empty, request.Description);
                byte[] bytes = GetWkbPolygon(request.Points);
                cmd.Parameters.Add(new NpgsqlParameter(string.Empty,
bytes));
                int id = (int)cmd.ExecuteScalar();
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Emilie Laffray
Sent: Friday, December 11, 2009 1:13 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Weird GEOS problem
2009/12/11 George Vlahakis <g.vlahakis at telenavis.com>
Hi all,
Probably nobody has seen this, but on a particular machine (Win XP)
every 2-3 hours or so I am getting the following error:
System.Data.Odbc.OdbcException: ERROR [XX000] ERROR: Error creating GEOS
Coordinate Sequence; Error while executing the query
I might be wrong but you are using .NET?
If it is indeed the case, I would suggest dropping the use of odbc, and
use npgsql which provides a direct connection to the database. It should
give you better performance, and maybe extra stability.
Emilie Laffray
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091216/e3c6663d/attachment.html>
