[postgis-users] plpgsql - problem using variable schema and table names
Birgit Laggner birgit.laggner at vti.bund.de
Tue Dec 22 03:58:04 PST 2009
Hi Kevin,
for the defining of n, your suggestions works perfectly well. But in the
next step, I try to assign a record as an intersection of 2 tables. I
tried to solve this with a nested loop. But the problem is, after
assigning the records for table a and b, I can't address certain fields
within the records anymore, which would be necessary for the
intersection loop.
By now, the part in question of my function looks like this (r_a, r_b
are declared as record, sql_a, sql_b are declared as text):
  sql_a := 'select gid, '||a_id||' as '||a_id||', the_geom from
'||quote_ident(schemaname)||'.'||quote_ident(table_a);
  raise debug '%', sql_a;
  raise notice '%', sql_a;
  sql_b := 'select gid, '||b_id||' as '||b_id||', the_geom from
'||quote_ident(schemaname)||'.'||quote_ident(table_b);
  raise debug '%', sql_b;
 FOR r_a in execute sql_a LOOP
 FOR r_b in execute sql_b LOOP
 FOR recordset_object IN execute 'select
   '||quote_ident(r_a.a_id) ||',
   '||quote_ident(r_b.b_id) ||',
   ST_intersection('||quote_ident(r_a.the_geom)||',
'||quote_ident(r_b.the_geom)||') AS the_geom
  WHERE st_intersects('||quote_ident(r_a.the_geom)||',
'||quote_ident(r_b.the_geom)||') and
        '||quote_ident(r_a.the_geom)||' && '||quote_ident(r_b.the_geom)
 LOOP
  execute
  'INSERT INTO ''||schemaname||''.''||intersection||'' (''||a_id||'',
''||b_id||'', the_geom) '||
   'VALUES ( '||
    ''||recordset_object||'.''||a_id||'', '||
    ''||recordset_object||'.''||b_id||'', '||
    ''||recordset_object||'.the_geom);';
 END LOOP;
 END LOOP;
 END LOOP;
And the error message, I get, is:
ERROR:  Record »r_a« hat no field »a_id«
Any ideas, how to handle this?
Thanks a lot and merry christmas,
Birgit.
On 17.12.2009 22:41, Kevin Neufeld wrote:
> Small typo ... it's not
> RAISE DEBUG '%s', sql;
> but
> RAISE DEBUG '%', sql;
>> http://www.postgresql.org/docs/8.4/static/plpgsql-control-structures.html#PLPGSQL-RECORDS-ITERATING
>> Try:
>> FOR target IN EXECUTE text_expression LOOP
>> END LOOP;
>> I usually do something like this:
>> DECLARE
>>   schemaname text := 'myschema';
>>   tablename text := 'mytable';
>>   sql text;
>>   r record;
>> BEGIN;
>>   sql := 'SELECT ... FROM ' || quote_ident(schemaname) || '.' ||
>> quote_ident(tablename);
>>   FOR r IN EXECUTE sql LOOP
>>   END LOOP
>> END;
>> -- Kevin
>> Birgit Laggner wrote:
>>> Yes, I have noticed that, but I don't know how to do that,
>>> especially at defining my n (loop end point variable). I tried
>>> various versions (also with execute), but without success.
>>> Birgit.
>>> On 17.12.2009 16:38, David William Bitner wrote:
>>>> Birgit,
>>>> The problem may be that you are creating a varchar variable for
>>>> your schema name and then you are trying to use it in an instance
>>>> that is expecting a database object. Anytime you are trying to
>>>> insert variables as database objects, you need to construct your
>>>> query as a string and use execute similar as to how you are
>>>> creating your insert statement.
>>>> David
>>>> On Thu, Dec 17, 2009 at 9:27 AM, Birgit Laggner
>>>> <birgit.laggner at vti.bund.de <mailto:birgit.laggner at vti.bund.de>>
>>>> wrote:
>>>>     Dear list,
>>>>     I am trying to generalize a pl/pgsql function I have written (see
>>>>     below). I would like to define schema and table names, as well as
>>>>     certain column names, in the function call (as in the PostGIS
>>>> function
>>>>     AddGeometryColumn) in order to use them to define schema and table
>>>>     names
>>>>     and everything else within the function queries.
>>>>     My problem is, that postgres doesn't recognize the defined
>>>> variable
>>>>     names if I call them in a FROM clause or INSERT INTO.  This is the
>>>>     error
>>>>     message:
>>>>     ERROR:  Schema »schemaname« does not exist
>>>>     LINE 1: SELECT  count( $1 ) from schemaname.table_a
>>>>     QUERY:  SELECT  count( $1 ) from schemaname.table_a
>>>>     CONTEXT:  PL/pgSQL function "_laggner_b_pgintersection" line 16 at
>>>>     assignment
>>>>     I can't imagine that it should be impossible to use variable
>>>>     schema and
>>>>     table names in a plpgsql function. So, if anybody has
>>>> suggestions, I
>>>>     would be quite happy.
>>>>     Thanks and regards,
>>>>     Birgit.
>>>>     My PostGIS version: 1.4.0-10.1
>>>>     My PostgreSQL version: 8.4.1-2.1
>>>>     My pl/pgsql function:
>>>>     CREATE OR REPLACE  FUNCTION _laggner_b_pgintersection(schemaname
>>>>     varchar(20), table_a varchar(50), a_id varchar(20), table_b
>>>>     varchar(50),
>>>>     b_id varchar(20), intersection varchar(60)) RETURNS void AS
>>>>     $BODY$
>>>>      DECLARE
>>>>      counter           integer;
>>>>      recordset_object  RECORD;
>>>>      i                 integer;
>>>>      n                 integer;
>>>>      BEGIN
>>>>      counter := 0;
>>>>      n := count(a_id) from schemaname.table_a;
>>>>     --1. Intersection:
>>>>      FOR i in 1..n LOOP
>>>>      RAISE NOTICE 'Beginn Intersection Tabelle 1, Polygon %', i;
>>>>      SELECT
>>>>       a.a_id ,
>>>>       b.b_id,
>>>>       ST_intersection(a.the_geom, b.the_geom) AS the_geom
>>>>      FROM schemaname.table_a a, schemaname.table_b b
>>>>      WHERE a.a_id=i and
>>>>            st_intersects(a.the_geom, b.the_geom) and
>>>>            a.the_geom && b.the_geom
>>>>      LOOP
>>>>      execute
>>>> (''||a_id||'',
>>>>       'VALUES ( '||
>>>>     alternatively:
>>>>      INSERT INTO schemaname.intersection (a_id, b_id, the_geom)
>>>>       VALUES (
>>>>        recordset_object.a_id,
>>>>        recordset_object.b_id,
>>>>        recordset_object.the_geom);
>>>>      counter := counter + 1;
>>>>      RAISE NOTICE 'Schreibe Intersection-Polygon %', counter ;
>>>>      END LOOP;
>>>>      counter := 0;
>>>>      END LOOP;
>>>>      END;
>>>>     $BODY$
>>>>     LANGUAGE 'plpgsql' VOLATILE;
>>>>     ALTER FUNCTION _laggner_b_pgintersection(schemaname varchar(20),
>>>>     table_a
>>>>     varchar(50), a_id varchar(20), table_b varchar(50), b_id
>>>> varchar(20),
>>>>     intersection varchar(60)) OWNER TO postgres;
>>>>     _______________________________________________
>>>>     postgis-users mailing list
>>>>     postgis-users at postgis.refractions.net
>>>>     <mailto:postgis-users at postgis.refractions.net>
>>>>     http://postgis.refractions.net/mailman/listinfo/postgis-users
