[postgis-users] schema
Kevin Neufeld kneufeld at refractions.net
Tue Dec 22 09:21:59 PST 2009
You only need to install PostGIS once, into one schema, typically 'public'.    As long as your user's search_path
contains the schema you installed PostGIS into, you'll have access to all the PostGIS functions, no matter what schema
you are referencing.
You can read up on schemas here:
http://www.postgresql.org/docs/8.4/static/ddl-schemas.html
Cheers,
Kevin
Malm Paul wrote:
> Hi,
> how can I create a secondary schema that includes all postgis functions as the default schema does?
> Kind regards,
> Paul
> postgis-users mailing list
