[postgis-users] Cleaning non valid multipolygon
Yves Moisan yves.moisan at boreal-is.com
Tue Feb 3 06:09:50 PST 2009
> This may work, but be careful!  ST_Union is designed to work on *valid*
> geometries.
Right.  I specifically owrk with the non valid geometries to begin
with.
> -- Here's how I would rebuild your geometry
> SELECT ST_AsText(
>    -- properly deals with polygon holes
>    ST_BuildArea(
>       -- generate properly noded linework
>       ST_Union(
>          ST_Boundary(column1),
>          ST_Startpoint(ST_Boundary(column1))
> FROM ( VALUES ('MULTIPOLYGON(((
> 376249.7830234 8717655.6050357,
> 376268.0818048 8717666.0116082,
> 376265.2666038 8717670.5117466,
> 376247.812391 8717660.3864341,
> 376249.7830234 8717655.6050357)))'::geometry)) AS foo;
Thanx Kevin.  That worked superbly!  I had to add multi() to the whole
bit because I had a constraint on multipolygons, so here is how I
cleaned my non valid geometries, for the record :
UPDATE MyTable g set the_geom =
multi(
  ST_BuildArea(
      ST_Union(
         ST_Boundary(foo.the_geom),
         ST_Startpoint(ST_Boundary(foo.the_geom))
FROM (SELECT the_geom, gid
FROM MyTable
WHERE NOT ST_IsValid(the_geom)
) As foo
WHERE g.gid = foo.gid
Thanx again and thanx community (Simon and Düster in particular).
Yves
