[postgis-users] Re: Test the Future (GEOS 3.1RC2)
Bruce Rindahl rindahl at lrcwe.com
Tue Feb 3 10:52:48 PST 2009
I have the --with-pg_config and --with-projdir define so configure
works.  Make gives the following error:
make[1]: Entering directory `/home/bruce/postgis-svn/loader'
gcc -g -O2  -DDLL_EXPORT -DPIC  -Wall -Wmissing-prototypes -liconv -lm
stringbuffer.o shpopen.o dbfopen.o shp2pgsql-core.o shp2pgsql-cli.o
../liblwgeom/liblwgeom.a -o shp2pgsql-cli.exe
shp2pgsql-core.o: In function `pgis_logf':
C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:177:
undefined reference to `vasprintf'
shp2pgsql-core.o: In function `DropTable':
C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1518:
undefined reference to `asprintf'
C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1538:
C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1510:
C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1530:
shp2pgsql-core.o: In function `utf8':
C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1677:
undefined reference to `libiconv_open'
C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1695:
undefined reference to `libiconv'
C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:1701:
undefined reference to `libiconv_close'
shp2pgsql-core.o: In function `LoadData':
C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:739:
C:/msys/1.0/home/bruce/postgis-svn/loader/shp2pgsql-core.c:744:
collect2: ld returned 1 exit status
make[1]: *** [shp2pgsql-cli.exe] Error 1
make[1]: Leaving directory `/home/bruce/postgis-svn/loader'
make: *** [loaderdumper] Error 2
Any suggestions here?
Thanks!
Bruce
Mark Cave-Ayland wrote:
> Bruce Rindahl wrote:
>> Using WinXP SP3 and MingW.  Compiled and installed GEOS-3.1.0rc2.
>> Compiled and installed PostgreSQL-8.3.5.
>> I got the following errors when running configure  postGIS-1.1.0SVN:
>> configure: error: the PGXS Makefile
>> c:/Postgresql/8.3/lib/pgxs/src/makefiles/pgxs.mk cannot be found.
>> Please install the PostgreSQL server development packages and re-run
>> configure.
>> What did I miss?
>> Thanks
>> Bruce
> Hi Bruce,
> I'd say that configure has picked up the wrong pg_config from the
> system path - make sure you explicitly choose the MingW pg_config
> using the --with-pgconfig=/c/path/to/mingw/pg_config option.
> HTH,
> Mark.
