[postgis-users] Donut-Polygon
Simon Greener simon at spatialdbadvisor.com
Thu Feb 5 15:57:14 PST 2009
Or, if you want to filter by area (POLYGON and MULTIPOLYGON), see this: http://www.spatialdbadvisor.com/postgis_tips_tricks/92/filtering-rings-in-polygon-postgis
regards
Simon
On Fri, 06 Feb 2009 05:29:15 +1100, Kevin Neufeld <kneufeld at refractions.net> wrote:
> Use ST_DumpRings to extract the rings, then exclude the ones you don't want and then rebuild your polygon.
> http://postgis.refractions.net/documentation/manual-svn/ST_DumpRings.html
> ie.
> -- A polygon with 6 inner rings, we exclude all but rings 3 and 5
> SELECT ST_AsText(ST_BuildArea(ST_Collect(geom))) AS the_geom
> FROM (SELECT (ST_DumpRings(
>      'POLYGON (( 0 0, 0 7, 10 7, 10 0, 0 0 ),
>                ( 1 4, 3 4, 3 6, 1 6, 1 4 ),
>                ( 4 4, 6 4, 6 6, 4 6, 4 4 ),
>                ( 7 4, 9 4, 9 6, 7 6, 7 4 ),
>                ( 1 1, 3 1, 3 3, 1 3, 1 1 ),
>                ( 4 1, 6 1, 6 3, 4 3, 4 1 ),
>                ( 7 1, 9 1, 9 3, 7 3, 7 1 )
>                )'::geometry)).*) AS foo
> WHERE NOT ( ARRAY[1,2,4,6] @> path );
>                                     the_geom
>   POLYGON((0 0,0 7,10 7,10 0,0 0),(7 4,9 4,9 6,7 6,7 4),(4 1,6 1,6 3,4 3,4 1))
> (1 row)
> Cheers,
> Kevin
> Albert Krueger wrote:
>> Hi at all,
>> I have a Donut-Polygon with a number of Innerrings. Now I would like to
>> delete some Innerrings. For Example I have a polygon with five
>> Innerrings. ButI want to delete the second and the fourth Innerring. Has
>> anyone an idea how I can get a polygon with only three Innerrings
>> (1,3,5) then?
>> Thank you!
>> Best regards
>> Albert
>> _________________________________
>> LOVE at LYCOS ist jetzt ganz neu - melde dich kostenlos an, lerne neue
>> Leute kennen und finde deinen Flirt!
>> Jetzt flirten!
>> <http://bc.lycos-europe.net/lnl/bc.php?loveatlycos_promo_mailsig|http://love.lycos.de/start.action?utm_campaign=mp&utm_source=mailsig>
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
  Email: simon at spatialdbadvisor.com
  Voice: +613 9016 3910
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
NAC:W80CK 7SWP3
