[postgis-users] Upgrade from 1.3.1 to 1.3.5
Obe, Regina robe.dnd at cityofboston.gov
Fri Feb 20 06:55:44 PST 2009
Devrim,
I think if you are just going from 1.3.1 to 1.3.5 running the
lwpostgis_upgrade.sql
should be all you need to do.  I don't think any aggregate functions were changed between those 2 which is usually the thing that doesn't come over with minor versions.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Devrim GÜNDÜZ
Sent: Friday, February 20, 2009 6:09 AM
To: PostGIS Users Discussion
Subject: [postgis-users] Upgrade from 1.3.1 to 1.3.5
Is there anything that we should do while upgrading from 1.3.1 to 1.3.5,
like dumping /restorin something or running a script?
Thanks,
Devrim GÜNDÜZ, RHCE
devrim~gunduz.org, devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
                   http://www.gunduz.org
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
