[postgis-users] ST_AsSVG crashes with large/complex geometries
Mike Leahy mgleahy at alumni.uwaterloo.ca
Sat Feb 21 04:54:04 PST 2009
Ok...the issue is posted here.  There's sample geometries there if you
want to give it a shot Marco.
Mike Leahy wrote:
> Hi Mark,
> Sorry for the delay - I've been on the road a bit.  I've got
> postgresql-8.3.6, and postgis-1.3.5, both installed from the Fedora 10
> repos.
> I'll report this as a bug sometime in the next few days when I have a
> bit of time to put a sample together...unless anyone has any other
> suggestions?
> Mike
>> Message: 22
>> Date: Thu, 19 Feb 2009 14:18:16 +0000
>> From: Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk>
>> Subject: Re: [postgis-users] ST_AsSVG crashes with large/complex
>>     geometries
>> To: mgleahy at alumni.uwaterloo.ca,    PostGIS Users Discussion
>>     <postgis-users at postgis.refractions.net>
>> Message-ID: <499D6A28.5080102 at siriusit.co.uk>
>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>> Mike Leahy wrote:
>>> > Hello list,
>>> > > I'm wondering if anyone has run into issues with st_assvg locking
>>> up > postgresql.  I have an application that generates svg from
>>> unioned sets > of geometries.  So far it has been working pretty
>>> well, except I just > tested it with very large sets of geometries,
>>> and it invariably locks up > the backend database without any errors
>>> etc.  I could send a sample > geometry if that would help, but I
>>> think this can probably be done with > any dataset.  I've verified
>>> that the problem is not with st_union, as it > outputs a geometry
>>> just fine...it's only when it gets to st_assvg does > it freeze
>>> things...there is no CPU activity.  I do see this in the pg_log:
>>> > > *** glibc detected *** postgres: postgres testdb [local] SELECT:
>>> > realloc(): invalid next size: 0x000000000220f410 ***
>>> > > Am I just expecting too much of the st_assvg function, or is this
>>> > something that might be fixable?
>>> > > Thanks for any advice,
>>> > Mike
>> Hi Mike,
>> Yeah, that sounds like a bug. What versions of PostgreSQL/PostGIS are
>> you using? You may want to open a bug with a sample geometry on the
>> PostGIS bugtracker.
>> ATB,
>> Mark.
