[postgis-users] Import GeoDB into PostGIS?
Abram Gillespie abe.gillespie.lists at gmail.com
Mon Feb 23 07:53:25 PST 2009
Matthew,
Thank you for the tip.  This seems to be about the most viable option
(short of a custom export solution ... which just might be what the
doctor ordered).
-Abe
On Mon, Feb 23, 2009 at 9:36 AM, Matthew Snape <SnapeM at rpsgroup.com> wrote:
> Do you have access to ArcGIS?  If so have a look at the Data
> Interoperability extension.  It uses FME, and in my experience does a
> very good job at uploading to PostGIS.  You can usually get a trial
> licence of the extensions if it's a one time thing.
> Matthew
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Abram Gillespie
> Sent: 23 February 2009 14:06
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Import GeoDB into PostGIS?
> Thank you for the help, everyone.
> Turns out I misunderstood the requirement.  The file format is, in
> fact, a "File Geodatabase" (as introduced in ArcGIS 9.2).  There are
> no tools yet that support this format, right?  Again, it's size is so
> large that converting to an intermediate format does not work.
> Thanks again,
> -Abe
> On Thu, Feb 19, 2009 at 10:43 AM, Chris Hermansen
> <chris.hermansen at timberline.ca> wrote:
>> ogr2ogr will save you.
>> Abram Gillespie wrote:
>>> Is there a direct way (something akin to shp2pgsql) to import data
>>> from a personal geodatabase?  I have an acquaintance whose geodb is
> so
>>> large that exporting to shp always times out.  Was hoping there was a
>>> way to skip the middle step.
>>> Thanks!
>>> -Abe
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Regards,
>> Chris Hermansen         mailto:chris.hermansen at timberline.ca
>> tel+1.604.714.2878 * fax+1.604.733.0631 * mob+1.778.232.0644
>> Timberline Natural Resource Group * http://www.timberline.ca
>> 401 * 958 West 8th Avenue  * Vancouver BC * Canada * V5Z 1E5
> This e-mail message and any attached file is the property of the sender and is sent in confidence to the addressee only. The contents are not to be disclosed to anyone other than
> the addressee. Unauthorised recipients are requested to preserve this confidentiality and to advise the sender immediately of any error in transmission. If you experience difficulty
> with opening any attachments to this message, or with sending a reply by email, please telephone on + 44-(0)1235 438151 or fax on + 44-(0)1235 438188.
> Any advice contained in this e-mail or any accompanying file attached hereto is for information purposes only. RPS do not take any responsibility for differences between the original
> and the transmission copy or any amendments made thereafter. If the addressee requires RPS to be responsible for the contents of this e-mail, RPS will be pleased to issue a signed
> hard copy of the document upon request.
> RPS Planning and Development Limited, company number: 02947164 (England). Registered office: Centurion Court, 85 Milton Park Abingdon Oxfordshire OX14 4RY.
> RPS Group Plc web link: <http://www.rpsgroup.com>
