[postgis-users] Editing PostGIS
Michael Toews mwtoews at sfu.ca
Tue Feb 24 14:39:38 PST 2009
Hi Don,
If you can view the geometry and attribute data in AutoCAD Map 3D 2008, then you are in a good position to start editing from the same software.
First, make sure that you have the correct permissions to edit the data. You can test this in pgAdmin by logging in with the same username/password as the fdo connection, and try to edit some attributes in the spatial data table.
A few other things: make sure there is 1 geometry column listed in geometry_columns; the linked table must be a table -- not a view (even if you make rules to enable insert/update/delete).
If this doesn't work, try different DLLs for FDO. We are using "Not Logged FdoPg32.zip" from http://www.geomapgis.com/web/geomap-group/fdo/
-Mike
----- Original Message -----
To: postgis-users at postgis.refractions.net
Sent: Monday, 23 February, 2009 14:12:55 GMT -08:00 US/Canada Pacific
Subject: Re: [postgis-users] Editing PostGIS
Thank you very much Fred!
I can now see the data but I am still unable to edit that. Is there
something that I am missing?
Thanks
Mike Toews wrote:
> Just be aware of the limitations (listed on the FDO wiki link below),
> otherwise the setup with Map3D 2008 mostly works. Use fdo-users mail list
> (http://lists.osgeo.org/mailman/listinfo/fdo-users) if you run into any
> issues.
> -Mike
> From: "Fred Lehodey" <lehodey at gmail.com>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Tuesday, 10 February, 2009 13:01:06 GMT -08:00 US/Canada Pacific
> Hi,
> yes with FDO :
> http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes
> Fred.
> On Tue, Feb 10, 2009 at 8:46 PM, Don C. Macgregor < sir_sunkee at yahoo.ca >
> wrote:
> Hi all,
> Is there any way to edit PostGIS data through AutoCAD Map 2008?
> Thanks
> postgis-users mailing list
View this message in context: http://www.nabble.com/Editing-PostGIS-tp21942202p22171260.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
