[postgis-users] Noobie question: How do I load Tiger Polygon data into PostGIS
Ron M rm_postgis at cheapcomplexdevices.com
Wed Feb 25 22:34:02 PST 2009
Sean Ferenci wrote:
> I am going through your documentation on how to load Tiger data that was
> at:
> http://geoserver.org/display/GEOSDOC/Loading+TIGER+polygons
> I cannot find either the tigerpoly.py script nor the recommended
>     tigerpolygonformation.zip fil
> Thanks in advance for your help.
As others pointed out, you almost certainly want to use the newer
tiger files that are distributed as shapefiles; but if you really
need to load the old TIGER format, attached is a little C program
that converts the old files to postgres/postgis insert statements.
Type: text/x-csrc
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090225/a0d0a402/attachment.c>
