[postgis-users] Error using PostGIS and GEOM
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Feb 27 07:11:32 PST 2009
Giri wrote:
> Thanks for the response, mmm I am using Geoserver (version1.7.2) , and
> when I try to create the featureType "polygon", it is complaining about
> class org.postgresql.util.PSQLException: ERROR: function
> extent(geometry) does not exist
> shouldn't PostGIS  have some backword support for the extent function?
> thanks!
> Giri
Hi Giri,
There has been talk of removing the old non-ST prefix functions from
PostGIS, but so far this hasn't happened. Perhaps you need to check your
installation?
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
