[postgis-users] Strange behaviour with st_difference
    Mark Cave-Ayland
    mark.cave-ayland at siriusit.co.uk
    Tue Jan 13 01:04:15 PST 2009
Mike Leahy wrote:
> Hello list,
> I'm having a problem with st_difference, where two overlapping
> geometries will return an empty geometrycollection, as if the do not
> overlap.  However, if I use st_difference on the same geometries, but
> converted to EWKT, then back, then using st_difference yields the
> expected output.  Basically, this is what I'm getting (minus the output
> coords):
> # select st_astext(st_difference(g1,g2)),
> st_astext(st_difference(st_asewkt(g1),st_asewkt(g2))) from temp;
>         st_astext         |  st_astext
>  GEOMETRYCOLLECTION EMPTY | POLYGON(( .... ))
> (1 row)
> The resulting (correct) polygon is very small (a total area of
> 0.00048828125, using UTM coordinates), so maybe there's a problem with
> that?  The result of st_overlaps(g1,g2) is true for the same data that
> cause this problem.
> I could email someone the geometries if that would help.
> Regards,
> Mike
Hi Mike,
I think you'll have to post the geometries if you want someone to help
you. If they are large then place them in a text file and send it to the
list as a zipped/gzipped attachment.
Oh, and don't forget the output of "SELECT postgis_full_version()" while
you're at it :)
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
