[postgis-users] Can't QGIS see GRASS tables in PostGIS??
Paragon Corporation lr at pcorp.us
Sun Jul 5 00:37:21 PDT 2009
Thybério,
I don't think QGIS relies on the geometry field being called anything in
particular, but I think it only shows a table/view in the list if the
geometry column is registered in the geometry_columns table.
So do a
SELECT * FROM geometry_columns;
And verify that your new vector layer table is listed there.  I'm not too
familiar with GRASS, but it could be its not creating a geometry column at
all and just a regular old PostgreSQL table with no geometry column.
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of thyberio
Sent: Saturday, July 04, 2009 11:00 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Can't QGIS see GRASS tables in PostGIS??
Hi all,
I have a GRASS location with driver=pg. When i save a new vector GRASS layer
in a PostGIS table, it can't be seen by QGIS through "add postgis layer". In
this way i can't see views created from this table too. I noted that the
column the_geom doesn't appear in the table. Is that the problem? Don't they
have compatibility?
I'm using:
Ubuntu 9.04 - GRASS64 - PostgreSQL 8.3 - PostGIS 1.3.3-3 - QGIS 1.1
Help meeeee!!!!
Thybério Luna - Brazil
View this message in context:
http://www.nabble.com/Can%27t-QGIS-see-GRASS-tables-in-PostGIS---tp24339709p
24339709.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
