[postgis-users] casting a geometry
Luigi Castro Cardeles luigi.cardeles at gmail.com
Wed Jun 3 12:24:44 PDT 2009
Hi
if they are polygon's, you can turn then into multi
ST_Multi(geometry)
Returns the geometry as a MULTI* geometry. If the geometry is already a
MULTI*, it is returned unchanged.
SELECT ST_MULTI(wkb_geometry) FROM table;
See if your postgis version have that function.
best regards,
2009/6/3 Richard Greenwood <richard.greenwood at gmail.com>
> I am having trouble inserting geometries into a table. The geometry
> column has a constraint:
>   enforce_geotype_wkb_geometry CHECK (geometrytype(wkb_geometry) =
> 'MULTIPOLYGON'::text
>      OR wkb_geometry IS NULL);
> I am attempting to insert what I assume are polygons generated by
> st_buffer() but they violate the constraint. If I pgsql2shp the
> polygons out I can insert them into the table, but that's pretty ugly.
> Thanks,
> Richard Greenwood
> www.greenwoodmap.com
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090603/5a96165f/attachment.html>
