[postgis-users] network generation question.
Kevin Neufeld kneufeld at refractions.net
Sun Jun 14 21:13:03 PDT 2009
Hi Jeff,
I just posted a page to the PostGIS wiki that might help you.  Let me
know if I can clarify anything for you.
http://trac.osgeo.org/postgis/wiki/UsersWikiExamplesNetworkTopology
Cheers,
Kevin
Jeff Hamann wrote:
> PostGIS Community:
> I've been chewing on this for the last day or so, and could use some
> guidance on the following situation because I think I'm doing some
> poorly.
> 1) I have a set of linestrings that represent road segments.
> 2) I need to generate a table that contains a
> from_node,to_node,linestring where the from_node/to_nodes are the
> points of intersection.
> 3) I'm a newbie with st_intersection and my query so far is:
> -- break the existing multilinestringm's into something managable.
> drop table if exists temproads;
> create table temproads as select *, st_force_2d(
> ST_GeometryN(centerline,1) ) as cline FROM road_lines where
> ST_NumGeometries(centerline) = 1;
> insert into temproads select *, st_force_2d(
> ST_GeometryN(centerline,2) ) as cline FROM road_lines where
> ST_NumGeometries(centerline) = 2;
> create table
>      roads2 as
> select
>   r1.trid as from_id,
>   r2.trid as to_id,
>   Relate( r1.cline, r2.cline ) as relate,
>   ST_Intersection( r1.cline, r2.cline ) as st_intersection
> from
>   temproads r1,
>   temproads r2
> where
>  intersects( r1.cline, r2.cline )
> order by
>     r1.trid,
>        r2.trid;
> The results look nice on the screen, but then I need to break up the
> linestrings into segments between where the two linestrings touch.
> When I dig a little deeper, it looks like all of the original parts
> are there, and I can write the additional code to extract out the new
> line segments, end nodes (from/to), and build a new table from
> scratch, but I'm not sure I'm doing this smartly.
> So my question is this:
> 1) Given a bunch of linestrings (multilinestrings), is it possible to,
> in one or two postgis queries, to generate a network graph with edges
> (as linestrings) and verticies (as points) where each linestring has
> the from vertex and the to vertex from the newly created points, in
> addition to the corresponding linestring between the two?
> Thanks for PostGIS!
> Jeff Hamann, PhD
> PO Box 1421
> Corvallis, Oregon 97339-1421
> 541-754-2457
> jeff.hamann[at]forestinformatics[dot]com
> http://www.forestinformatics.com
> postgis-users mailing list
