[postgis-users] compundcurve in polygons is supported in 1.4
Obe, Regina robe.dnd at cityofboston.gov
Tue Jun 30 05:12:04 PDT 2009
Mario,
Actually Mark L just fixed the bug  in trunk (and he is patching the fix into 1.4 and I believe 1.3 as well).  So it will be fully functional in PostGIS 1.4 probably due out next week and 1.3 about a month later.
st_curvetoline has always worked with curve polygons (with either circularstring or linestring like inner rings) and converts those to regular polygons even if they have holes (the name is a bit confusing http://postgis.refractions.net/documentation/manual-svn/ST_CurveToLine.html ) but for 1.4 and 1.3, it will very shortly work for
curve polygons with compound curves.  It hasn't been really stress tested, so feel free to test it when it comes out.
Here are related bug tickets just recently patched
http://trac.osgeo.org/postgis/ticket/213
http://trac.osgeo.org/postgis/ticket/212
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mario Jurcevic
Sent: Tuesday, June 30, 2009 3:09 AM
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] compundcurve in polygons is supported in 1.4
thanks very much I really need this datatype.
Will be possible to create polygons with multiple rings of compoundcurve?
A function like stcurvetoline with the interpolation of arcs will be
available for the polygons too?
Thanks
Mario
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paragon
Corporation
Sent: lunedì, 29. giugno 2009 04:03
Actually I think I spoke too soon on this one.  Still apparently some issues
here.
Corporation
Sent: Sunday, June 28, 2009 9:42 PM
Mario,
Sorry for no one getting back to you.  This is actually available in the
upcoming PostGIS 1.4 due out within the next 2 weeks. I had to test it to
verify myself.  So yes as of PostGIS 1.4 you can do this.
SELECT ST_GeomFromEWKT('CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(0 0,2 0, 2
1, 2 3, 4 3),(4 3, 4 5, 1 4, 0 0)))');
I tried the same on PostGIS 1.3.6 and it doesn't work so guess you have to
wait for 1.4.
Hope that helps,
Regina
Jurcevic
Sent: Thursday, June 18, 2009 4:25 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] compundcurve in polygons
Postgis community will develop compundcurve in polygons?
I will help with my work or with sponsoring a developper for code it.
Thanks
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
