[postgis-users] Re: [pgsql-es-ayuda] instalar postgis
Z.M. nramire1 at rosario.gov.ar
Mon Mar 2 01:59:32 PST 2009
En Fri, 27 Feb 2009 16:32:41 -0300, Emanuel Calvo Franco <postgres.arg at gmail.com> escribió:
> 2009/2/27 Z.M. <nramire1 at rosario.gov.ar>:
>> Hola a todos. Estuve tratando de instalar postgis sobre postgresql
>> Instale postgresql desde el gestor de paquetes synaptic de la distribucion de debian.
>> al intentar instalar postgis me da el siguiente error:
>> casa:/home/usuario# psql -version
>> psql: FATAL:  no existe la base de datos «root»
>> casa:/home/usuario# psql --version
>> psql (PostgreSQL) 8.1.11
>> incluye soporte para edición de línea de comandos
>> casa:/home/usuario# cd postgis-1.3.5
>> casa:/home/usuario/postgis-1.3.5# make # make install
>> ./configure
>> checking for gcc... gcc
>> checking for C compiler default output file name... a.out
>> checking whether the C compiler works... yes
>> checking whether we are cross compiling... no
>> checking for suffix of executables...
>> checking for suffix of object files... o
>> checking whether we are using the GNU C compiler... yes
>> checking whether gcc accepts -g... yes
>> checking for gcc option to accept ISO C89... none needed
>> checking for g++... g++
>> checking whether we are using the GNU C++ compiler... yes
>> checking whether g++ accepts -g... yes
>> checking whether ln -s works... yes
>> checking for iconv_open in -liconv... no
>> checking for libiconv_open in -liconv... no
>> checking for iconv_open in -lc... yes
>> checking how to run the C preprocessor... gcc -E
>> checking for grep that handles long lines and -e... /bin/grep
>> checking for egrep... /bin/grep -E
>> checking for ANSI C header files... yes
>> checking for sys/types.h... yes
>> checking for sys/stat.h... yes
>> checking for stdlib.h... yes
>> checking for string.h... yes
>> checking for memory.h... yes
>> checking for strings.h... yes
>> checking for inttypes.h... yes
>> checking for stdint.h... yes
>> checking for unistd.h... yes
>> checking iconv.h usability... yes
>> checking iconv.h presence... yes
>> checking for iconv.h... yes
>> checking build system type... x86_64-unknown-linux-gnu
>> checking host system type... x86_64-unknown-linux-gnu
>> checking for pg_config... no
>> configure: error: PostgreSQL is required by PostGIS
>> make: *** [config.status] Error 1
>> ¿que me esta faltando para poder instalar postgis?
>> Z.M.
>> TIP 8: explain analyze es tu amigo
> Esta corriendo Postgres?
Si, se inicia cuando enciendo la pc.
Z.M.
