[postgis-users] Error using PostGIS and GEOM
Kevin Neufeld kneufeld at refractions.net
Mon Mar 2 08:43:52 PST 2009
Just a random thought here.  Did you accidentally install PostGIS in a schema other than public?   If so, is that schema
on the search_path of the user you are using to connect within GeoServer?
Do you get the same answer when you do this from psql or PgAdminIII?
postgis=# select public.extent('POINT(0 0)');
     extent
  BOX(0 0,0 0)
(1 row)
Cheers,
Kevin
Giri wrote:
> Hi Mark,
> I am using the latest stable versions of Geoserver and PostGIS, the
> installation looks good, no errors were reported.
> Thanks!
> Giri
> On Fri, Feb 27, 2009 at 10:11 AM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk
> <mailto:mark.cave-ayland at siriusit.co.uk>> wrote:
>     Giri wrote:
>         Thanks for the response, mmm I am using Geoserver (version1.7.2)
>         , and when I try to create the featureType "polygon", it is
>         complaining about
>         class org.postgresql.util.PSQLException: ERROR: function
>         extent(geometry) does not exist
>         shouldn't PostGIS  have some backword support for the extent
>         function?
>         thanks!
>         Giri
>     Hi Giri,
>     There has been talk of removing the old non-ST prefix functions from
>     PostGIS, but so far this hasn't happened. Perhaps you need to check
>     your installation?
>     HTH,
>     Mark.
>     Mark Cave-Ayland - Senior Technical Architect
>     PostgreSQL - PostGIS
>     Sirius Corporation plc - control through freedom
>     http://www.siriusit.co.uk
>     t: +44 870 608 0063
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at postgis.refractions.net
>     <mailto:postgis-users at postgis.refractions.net>
>     http://postgis.refractions.net/mailman/listinfo/postgis-users
