[postgis-users] pb OpenLayers using a local Mapserver
Quentin Page Quentin.Page at ensg.eu
Mon Mar 9 00:41:28 PDT 2009
thanks for your reponce
but i have the same probleme the data doesnt viewed.
quentin page
ecole des sciences géographique
france
> did you try this 'just'on mapserver, ie. without OpenLayers...? To me the
> URL to mapserver just seems to be wrong , I suspect that i.s.o.
>   'http://localhost/cgi-bin/mapserv?/projet2009/ICPE.map',
> it should read
>   'http://localhost/cgi-bin/mapserv?map=/projet2009/ICPE.map',
> Barend Köbben
> International Institute for Geo-information Sciences and  Earth
> Observation (ITC)
> PO Box 6, 7500AA Enschede (The Netherlands)
> ph: +31-(0)534874253
>   _____
> Van: postgis-users-bounces at postgis.refractions.net namens Quentin Page
> Verzonden: zo 8-3-2009 21:14
> Aan: postgis-users at postgis.refractions.net
> Onderwerp: [postgis-users] pb OpenLayers using a local Mapserver
> Hi,
> i have got a problem using openlayers with a mapserver.
> It seems that my use of the constructor doesnt work for any reason.
> The mapfile which should be viewed has already worked (in PHP).
> Could we help me please ? Is it the good way to create a openlayers ? :/
> var map = new OpenLayers.Map('map');
> var wms = new OpenLayers.Layer.WMS( "ICPE",
>         {layers: 'roads'},
>         {singleTile: true, opacity: 0.5, isBaseLayer : true}
> map.addLayer(wms);
> Thanks a lots !!!!!
> postgis-users mailing list
> International Institute for Geo-Information Science and Earth Observation
> (ITC)
> Chamber of Commerce: 410 27 560
> E-mail disclaimer
> The information in this e-mail, including any attachments, is intended for
> the addressee only. If you are not the intended recipient, you are hereby
> notified that any disclosure, copying, distribution or action in relation
> to the content of this information is strictly prohibited. If you have
> received this e-mail by mistake, please delete the message and any
> attachment and inform the sender by return e-mail. ITC accepts no
> liability for any error or omission in the message content or for damage
> of any kind that may arise as a result of e-mail transmission.
