[postgis-users] To install PostGis in the Windows Vista
RAVI KUMAR ravivundavalli at yahoo.com
Mon Mar 9 03:17:35 PDT 2009
If you still have problems..
1. Change UAC setup (to Off) in control panel
2. Create an administrator account
3. Log in as administrator and then do PostGIS installation.
Save a shape file in PostGIS as an acid test.
I see that problems vary with different installations even when the software remain same ?? Donno why ??
Cheers
Ravi Kumar
--- On Mon, 3/9/09, Ahmad Bdair <bdair2002 at gmail.com> wrote:
> From: Ahmad Bdair <bdair2002 at gmail.com>
> Subject: Re: [postgis-users] To install PostGis in the Windows Vista
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Date: Monday, March 9, 2009, 3:10 PM
> Use Application stack builder (which comes with posgres DB)
> to install it.
> On Mon, Mar 9, 2009 at 2:24 AM, <jamrr at cin.ufpe.br>
> wrote:
> > Please, would get some help to install the Postgis in
> the OS Windows Vista
> > . Thank you very much.
> > José Antonio
> > Recife, PE - Brazil.
> > postgis-users mailing list
