[postgis-users] PostGIS view in qgis
Martin Fafard martin.fafard at geoprojection.com
Mon Mar 9 08:10:39 PDT 2009
Eduin
Thank you for the answer but it doesn't work. Since I create new objects
from a view (polygonize), it seem to be impossible to create a unique id
in this view for these objects. Someone else have ever aggregate geom in
a view to see it in qgis or other viewer??
Martin F
Eduin Yezid Carrillo Vega a écrit :
> If your postgresql version is 8.0 or less you can use OID fields as
> key identifier.
> CREATE VIEW myview AS SELECT oid AS gid, the_geom FROM mytable;
> In postgresql 8.3 you can force oid creation if WITH OIDS is specified
> when the table is created
> Eduin Yesid Carrillo Vega
> Ingeniero Civil, Esp. Sistemas de Información Geográfica
> Centro de Investigación y Desarrollo en Información Geográfica
> Instituto Geográfico Agustín Codazzi - IGAC
> Cr 30 48-51
> Tel +57 1 3694000  ext 4593
> Bogotá D.C., Colombia
> On Mon, Mar 9, 2009 at 2:43 AM, Marc Jansen <jansen.marc at gmx.de> wrote:
>> HI Martin,
>> Martin Fafard schrieb:
>>> Hi
>>> I polygonize linestrings in a view to see the result in qgis. But qgis
>>> need gid. How can I create the gid column after an aggregate function in a
>>> view?
>> AFAIK you can't. Maybe a table (created by your query) with a serial /
>> primary key helps.
>> --Marc
>>> Martin F
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> No virus found in this incoming message.
>> Checked by AVG - www.avg.com
>> Version: 8.0.237 / Virus Database: 270.11.9/1990 - Release Date: 03/08/09 17:17:00
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090309/b6fafe71/attachment.html>
