[postgis-users] pb OpenLayers using a local Mapserver
Barend Kobben kobben at itc.nl
Tue Mar 10 10:45:08 PDT 2009
> yes I haved named every layers but I haven't bounding box.
I guess you mean there's no BBOX in the GetCapabilities reply?. That's not
good. I think (but others may correct me) that there is a bug/hidden feature
in teh PostGIS connector of Mapserver that it does not get the extent of a
layer if one is not provided to it (as it would happen with eg. shape file
datasources).
It is anyway more efficient to provide the Extent in the .map file, so
Mapserver doesn't have to search for it. I also notice you are missing the
WEB METADAT that wms requires. So I would advice to put in the LAYER:
      METADATA
        "wms_title" "your title"
        "wms_extent" "minx miny maxx maxy"
      END
Barend
On 10-03-09 17:01, "Quentin Page" <Quentin.Page at ensg.eu> wrote:
> hi barend,
> I wrote this in every my layers
> lAYER
> NAME "routes"
> STATUS DEFAULT
> METADATA
> "wms_title" "routes"
> END
> CONNECTION "user=postgres  password=postgres dbname= ICPE host=localhost
> port=5432"
> CONNECTIONTYPE POSTGIS
> DATA "wkb_geometry FROM (SELECT * from ligne_electrique where
> wkb_geometry&&GeomFromText('POLYGON((799287 1885037,799912
> 1885037,799912 1885662,799287 1885662,799287 1885037))',32767)) as foo
> using unique ogc_fid using SRID=32767"
> TYPE LINE
> CLASS
> NAME "routes"
> STYLE
> OUTLINECOLOR 10 10 10
> COLOR 0 20 255
> SIZE 4
> END
> END
> END
> END
> I can see the data when i use mapserver alone but I need openlayers to
> write a new feature.
> the extent is the same as the map.
> thank a lots
>> Yes, this is (part of) a valid getCapabilities. Further down there should
>> be
>> a section that describes the LAYERs, with for each layer at least a  TITLE
>> and a valid BBOX (= bounding box). Check if this bounding box is there and
>> is corresponding with the actual data you have. If not, there is an error
>> somewhere, most likely in the set up of your SRS (= spatial reference
>> system
>> = the projection of your map and your data), or the EXTENT (the part of
>> the
>> world you define your data to depict)....
>> Barend
>> On 09-03-09 16:10, "Quentin Page" <Quentin.Page at ensg.eu> wrote:
>>> yes I tried
>>> http://localhost/cgi-bin/mapserv.exe?map=ms4w/apache/htdon
>>> cs/projet2009/ICPE.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
>>> and I received a file mapserver.exe what I rename "mapserver.xml" this
>>> file wasn't empty.
>>> the message is for sevreal lines
>>> <DescribeLayer>
>>>       <Format>text/xml</Format>
>>>       <DCPType>
>>>         <HTTP>
>>>           <Get><OnlineResource
>>> xmlns:xlink="http://www.w3.org/1999/xlink"
>>> xlink:href="http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/pro
>>> je
>>> t2009/ICPE.map&"/></Get>
>>>           <Post><OnlineResource
>>> je
>>> t2009/ICPE.map&"/></Post>
>>>         </HTTP>
>>>       </DCPType>
>>>     </DescribeLayer>
>>>     <GetLegendGraphic>
>>>       <Format>image/gif</Format>
>>>       <Format>image/png</Format>
>>>       <Format>image/png; mode=24bit</Format>
>>>       <Format>image/jpeg</Format>
>>>       <Format>image/wbmp</Format>
>>>       <DCPType>
>>>         <HTTP>
>>> je
>>> je
>>>         </HTTP>
>>>       </DCPType>
>>>     </GetLegendGraphic>
>>> but i don't see the data
>>> OK, but did you try to get it working by just typing the URL in a
>>> browser?
>>>> That tests the actual Mapserver request, to see if that part of the
>>>> setup
>>>> works...
>>>> Something like:
http://localhost/cgi-bin/mapserv?map=/projet2009/ICPE.map&SERVICE=WMS&VERSI>>>>
O
>>>> N=1.1.1&REQUEST=GetCapabilities should result in a GetCapabilities XML
>>>> being
>>>> sent to you.
>>>> Barend
>>>> On 09-03-09 08:41, "Quentin Page" <Quentin.Page at ensg.eu> wrote:
>>>>> thanks for your reponce
>>>>> but i have the same probleme the data doesnt viewed.
>>>>> quentin page
>>>>> ecole des sciences géographique
>>>>> france
>>>>>> did you try this 'just'on mapserver, ie. without OpenLayers...? To me
>>>>>> the
>>>>>> URL to mapserver just seems to be wrong , I suspect that i.s.o.
>>>>>>   'http://localhost/cgi-bin/mapserv?/projet2009/ICPE.map',
>>>>>> it should read
>>>>>>   'http://localhost/cgi-bin/mapserv?map=/projet2009/ICPE.map',
>>>>>> Barend Köbben
>>>>>> International Institute for Geo-information Sciences and  Earth
>>>>>> Observation (ITC)
>>>>>> PO Box 6, 7500AA Enschede (The Netherlands)
>>>>>> ph: +31-(0)534874253
>>>>>>   _____
>>>>>> Van: postgis-users-bounces at postgis.refractions.net namens Quentin
>>>>>> Page
>>>>>> Verzonden: zo 8-3-2009 21:14
>>>>>> Aan: postgis-users at postgis.refractions.net
>>>>>> Onderwerp: [postgis-users] pb OpenLayers using a local Mapserver
>>>>>> Hi,
>>>>>> i have got a problem using openlayers with a mapserver.
>>>>>> It seems that my use of the constructor doesnt work for any reason.
>>>>>> The mapfile which should be viewed has already worked (in PHP).
>>>>>> Could we help me please ? Is it the good way to create a openlayers ?
>>>>>> var map = new OpenLayers.Map('map');
>>>>>> var wms = new OpenLayers.Layer.WMS( "ICPE",
>>>>>>         {layers: 'roads'},
>>>>>>         {singleTile: true, opacity: 0.5, isBaseLayer : true}
>>>>>> map.addLayer(wms);
>>>>>> Thanks a lots !!!!!
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>> International Institute for Geo-Information Science and Earth
>>>>>> Observation
>>>>>> (ITC)
>>>>>> Chamber of Commerce: 410 27 560
>>>>>> E-mail disclaimer
>>>>>> The information in this e-mail, including any attachments, is
>>>>>> intended
>>>>>> for
>>>>>> the addressee only. If you are not the intended recipient, you are
>>>>>> hereby
>>>>>> notified that any disclosure, copying, distribution or action in
>>>>>> relation
>>>>>> to the content of this information is strictly prohibited. If you
>>>>>> have
>>>>>> received this e-mail by mistake, please delete the message and any
>>>>>> attachment and inform the sender by return e-mail. ITC accepts no
>>>>>> liability for any error or omission in the message content or for
>>>>>> damage
>>>>>> of any kind that may arise as a result of e-mail transmission.
>>>> Observation
>>>> (ITC)
>>>> E-mail disclaimer
>>>> The information in this e-mail, including any attachments, is intended
>>>> for
>>>> hereby
>>>> relation
>>>> to the content of this information is strictly prohibited. If you have
>>>> damage
>> International Institute for Geo-Information Science and Earth Observation
>> (ITC)
>> E-mail disclaimer
>> The information in this e-mail, including any attachments, is intended for
>> the addressee only. If you are not the intended recipient, you are hereby
>> notified that any disclosure, copying, distribution or action in relation
>> liability for any error or omission in the message content or for damage
International Institute for Geo-Information Science and Earth Observation (ITC)
E-mail disclaimer
The information in this e-mail, including any attachments, is intended for the addressee only. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution or action in relation to the content of this information is strictly prohibited. If you have received this e-mail by mistake, please delete the message and any attachment and inform the sender by return e-mail. ITC accepts no liability for any error or omission in the message content or for damage of any kind that may arise as a result of e-mail transmission.
